Bleed Valves
Brunton
Member Posts: 9
I'm converting our house from baseboard hot water to cast iron radiators. The only bleed valves I can find are the ones that Lowes and Home Depot usually carry, but these are a little short for some of the old refurbished radiators I'm using, and I can't get them tight enough not to leak slightly at the base.
Two questions - what is the absolutely best pipe dope out there, and are any of the older fancy bleed valves still available anywhere?
Radiator Bleed Valves
Thanks much!
Mark B.0 -
Try
a short 1/8" brass nipple and a coupling. Screw the bleeder into the coupling, it should work OK. Any good dope should work with these items.All Steamed Up, Inc.
Consulting0 -
I've searched and searched and searched for a source of bleed valves other than that "coin-key". ZERO success.0 -
lamp-wick
try a hoffman "500 " or a gorton self bleeder . plenty of meat. use teflon or use quick-wick spool lampwick with schmear. garanteed not to leak. use wick on all water related threads & no need to do it twice !0 -
Thanks, and another question
Thanks for the help on the leaking bleed valve. I got it fixed by chasing the threads with a tap and then putting in a new valve (coin-key). If the leak reoccurs I'll go with the short nipple and coupling.
Another question - One of the new valve spuds (3/4") bottoms out in the female adapter (a new adapter) and still leaks a little bit. I used Blue Block on the threads. I've noticed this was close on a couple of other radiators, but I did get seals. According to the NPT specs, the male shouldn't bottom out in the female, at least on new parts. How do I deal with this? Lampwick with the dope, or teflon tape with the dope (and how do I do that? tape / lampwick then dope?)? Sorry for the very basic questions - I'm not a professional plumber.
Thanks again for the help!
Mark B.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
