Bleed Valves
Brunton
Brunton Member Posts: 9
I'm converting our house from baseboard hot water to cast iron radiators. The only bleed valves I can find are the ones that Lowes and Home Depot usually carry, but these are a little short for some of the old refurbished radiators I'm using, and I can't get them tight enough not to leak slightly at the base.
Two questions - what is the absolutely best pipe dope out there, and are any of the older fancy bleed valves still available anywhere?
  • Brunton
    Radiator Bleed Valves
    Thanks much!
    Mark B.
    Steamhead Member Posts: 18,205
    Try
    a short 1/8" brass nipple and a coupling. Screw the bleeder into the coupling, it should work OK. Any good dope should work with these items.
    Consulting
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    I've searched and searched and searched for a source of bleed valves other than that "coin-key". ZERO success.
  • bob young
    bob young Member Posts: 2,177
    lamp-wick
    try a hoffman "500 " or a gorton self bleeder . plenty of meat. use teflon or use quick-wick spool lampwick with schmear. garanteed not to leak. use wick on all water related threads & no need to do it twice !
  • Brunton
    Thanks, and another question
    Thanks for the help on the leaking bleed valve. I got it fixed by chasing the threads with a tap and then putting in a new valve (coin-key). If the leak reoccurs I'll go with the short nipple and coupling.
    Another question - One of the new valve spuds (3/4") bottoms out in the female adapter (a new adapter) and still leaks a little bit. I used Blue Block on the threads. I've noticed this was close on a couple of other radiators, but I did get seals. According to the NPT specs, the male shouldn't bottom out in the female, at least on new parts. How do I deal with this? Lampwick with the dope, or teflon tape with the dope (and how do I do that? tape / lampwick then dope?)? Sorry for the very basic questions - I'm not a professional plumber.
    Thanks again for the help!
    Mark B.
