Carrier
Eugene Silberstein 3
Member Posts: 1,380
Yes Jay, Carrier is indeed a very good brand with an excellent reputation.
If you read other posts in this forum, you will
see numerous references to R-410a. Puron is Carrier's name for R-410a.
It is definitel a good idea to go with an R-410a system for two reasons: the higher EER and the fact that R-22 has already begun its phaseout process.
The total phase-out for R-22 will occur in 2020 and it can be expected that supplies will be short prior to then.
The R-22 phaseout began on January 1, 2004.
On the EER issue, 10 SEER units will no longer be available after December 31, 2005 so going with the higher SEER unit will definitely be a plus for you.
Just keep in mind that the initial cost of the 410a equipment will be higher than an equivalent R-22 system, but you will find that, in the longer term, it was money well spent.
Carrier
I am looking to get central Air and was wondering if Carrier is a good brand to go with. I am looking at the Carrier Puron series? I was told that the freon that is used now will be obsolete in five years and I should go with the Puron. It is also more efficient then the other models it is 15.5 SEER. Any advice would be helpful.
Jay0 -
clarification
13 SEER will be the minimum as of Jan 23, 2006. This means there will be no one allowed to manufacture it. Existing units manufactured prior to this date will be available for sale until existing supplied are used up.
Mitch0 -
Thank You
Thanks for the clarification, Mitch. Your input is always welcome.
Keep up the good work.0 -
If you are installing a new a/c system take a look at Carrier's Infinity system- you will need to have A variable speed drive on your air handler/furnace. Also check out their Infinity Control System- the coolest control on the market. Carrier also has an Infinity zone control system if needed. People are buying up to this system because it is extremely quiet, enhances the comfort level in the home, and will save on the utilities. take a look you'l' be impressed. Good luck0 -
Carrier Infinity System
I am a homeowner and had the new Infinity System installed last June. The unit has a SEER rating of 18. It has a two speed compresser and a variable speed air handler. It is the best money we have ever spent! It took our cooling costs from $150-200/month to $15-50/month! The system is very quiet and comfortable as well. Go with Carrier for refridigation but not boilers.0 -
Sounds Great!
An unsolicited testimonial... The best kind.0 -
and if you live near the ocean...
carrier's "coastal" model is the way to go, specifically designed to handle continuous salt air it gives up 2 points of EER though, simply because the condenser fins are that much ticker so its physically imposable to be the same EER without making the condenser coil huge
ps a common failure near the ocean is the little liquid line drier that comes with many condensers, since the driers casing is not copper, it dies first, I take them out, and put in a much larger flare nut one the larger flare nut ones seem ticker and last longer in that env
