where can I get an accurate thrermometer to measure super heat a
will smith_4
Member Posts: 259
C&D makes a superheat kit-it allows you to remove the schrader core and insert a temp probe to measure the gas directly. Can't get much closer than that!
where can I get an accurate thermometer?
I don't trust the ones I have? It's 2005, does an accurate thermometer exist yet? Especially one with easy clamping onto a round pipe.0 -
Ask TGO
Ask Tom from TGO about the success he's been having with the thermometer I hooked him up with.
Tom, can you supply the info (make, model, etc.) for Ken as well as any comments about your expeience with it.
Much appreciated.0 -
Thermometer
> with.
> Much
> appreciated.
Thermometer
I have a Check-it Superheat Pyrometer - available at Graingers. It has 3 temp probes and will calculate the temp differance between any two. It has magents on the back which hold fairly well ( don't leave the weight of 3 leads on it or it will slip). Don't bother with the velco straps just get a few big spring clips and put some insulation on the inside. It also comes in a nice plastic case. It only reads to the full degree - no tenths but for superheat, subcooling, and duct temps its fine.
FLUKE
MAKES A NICE PIPE CLAMP THERMOMETER. BEST $100.OO BUCKS
I EVER SPENT.OF COURSE YOU NEED A FLUKE METER TO PLUG IT INTO.BUT NEVER THE LESS A FINE DURABLE PIECE OF EQUIPMENT.
WILL CLAMP UPTO 1 3/8 OR MAYBE 1 5/8 ,i Belive.
mike.0 -
I just
purchase a meter from Cooper/Atkins that seem to do alot.
MFM300 does superheat/subcooling,Delta T,measure pressure.
relative humidiity,dry-bulb temps.display psychrometics.
Has a data logger,and data for up to 15 different refrigerants.Measure airflow
WWW.Cooper-Adkins.0 -
With what they charge for that mfm300 they should have at least included the 4005 clamp instead of a wrap around probe. Have the clamp and its great, think they also sell one that can be used in place of a k type thermocouple.0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
