horizontal furnace
Guy_6
Guy_6 Member Posts: 450
Although I am a HW guy (no pun intended), I have a Goodman horizontal furnace in the second floor of my house that vents in PVC.
I would check with the local inspectors before putting anything above a suspended ceiling in a living space: For some reason, I am not too comfortable with that.
Guy
  • paul sr.
    paul sr. Member Posts: 7
    horizontal furnace
    does anyone know of a horizontal gas furnace that would vent with pvc that could be installed above a suspended ceiling in an apartment? does such a thing exist? its for a buddy. thanks in advance.
  • Jeff Lawrence_24
    Jeff Lawrence_24 Member Posts: 593
    How much
    Room is up there? I know Rheem/Ruud make 90% horiz furnaces...
  • Cheeze-Tech
    Cheeze-Tech Member Posts: 84
    Horizontal Furnace
    Several manufacturers have 90+ eff. furnaces that are multipositional. They are funaces you can install upflow, downflow, or horizontal. Carrier/Bryant/Payne, Rheem/Ruud/Weatherking, & Heil/Tempstar/Comfortmaker/Arcoaire are ones that come to mind. They are all sealed combustion so should be able to be installed above a ceiling. Check with local codes. You would need to have a place for the condensate to drain to or be pumped to. Hope this helps.
    Cheez Tech
  • John Mills_5
    John Mills_5 Member Posts: 952
    As the other say
    the are plentiful. Remember you'll have to have a way to drain the condensate from the secondary.
