horizontal furnace
Guy_6
Member Posts: 450
Although I am a HW guy (no pun intended), I have a Goodman horizontal furnace in the second floor of my house that vents in PVC.
I would check with the local inspectors before putting anything above a suspended ceiling in a living space: For some reason, I am not too comfortable with that.
Guy
Guy
horizontal furnace
does anyone know of a horizontal gas furnace that would vent with pvc that could be installed above a suspended ceiling in an apartment? does such a thing exist? its for a buddy. thanks in advance.0 -
How much
Room is up there? I know Rheem/Ruud make 90% horiz furnaces...
Horizontal Furnace
Several manufacturers have 90+ eff. furnaces that are multipositional. They are funaces you can install upflow, downflow, or horizontal. Carrier/Bryant/Payne, Rheem/Ruud/Weatherking, & Heil/Tempstar/Comfortmaker/Arcoaire are ones that come to mind. They are all sealed combustion so should be able to be installed above a ceiling. Check with local codes. You would need to have a place for the condensate to drain to or be pumped to. Hope this helps.
Cheez Tech0 -
As the other say
the are plentiful. Remember you'll have to have a way to drain the condensate from the secondary.0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
