Ductulator
J. Francis
J. Francis Member Posts: 3
Does anyone know where to find a ductulator (sp?) or something similar on line to help me size some duct work?
  • don_109
    don_109 Member Posts: 1
    Check here
    www.acca.org...may I suggest the manual D system and application.Also understanding the friction chart is a good read as well.
  • don_108
    don_108 Member Posts: 1
    Francis
    keep in mind that all duct are not the same,so when using
    ductulator you want to have the one for the material you are
    using.
    Also keep in mind that most ductulator are base on fiction
    loss per 100 ft.All duct system are not the same,just as all
    duct material are not the same.
    Also if you get into the habit of doing a friction worksheet
    per job,you'll find not only do you offer a better distribution system,but you have the math to address any issue as well.
  • jim lockard
    jim lockard Member Posts: 1,059
    R.E. Michels
    Sells them, Along with most Hvac supply houses.
  • Empire_2
    Empire_2 Member Posts: 2,340
    ACCA
  • Empire_2
    ACCA
    Acca sells a nice one that will also give you the cfm ratings for flex and duct board if you run into it. It is a circular dial type and sells for about $40.00.
  • Matt_21
    Matt_21 Member Posts: 140
    your locat trane dealer
    should have one for about $5 or you can go to mcquay.com and download one onto your computer.
  • jeff_51
    jeff_51 Member Posts: 545
    GEE my suppliers gave them to me for buying their duct
  • Carl PE_2
    Carl PE_2 Member Posts: 42
    Also..
    There's one built into cook's "compute-a-fan".
  • Ken D.
    Ken D. Member Posts: 836
    Ductilater
    All the majors have them available-Lennox, Trane, Carrier, York,etc., as well as the RSES, ACCA, SMACNA, duct materials suppliers, HVAC suppliers,etc. Your local supply house should be able to get you one.
  • Mitch_4
    Mitch_4 Member Posts: 955
    link to
    ductalator doesn't work.
  • eric_2
    eric_2 Member Posts: 148
    ductolator
    If you want to drop me an e-mail with your info, I'll send you one out.
  • Dave Heath_2
    Dave Heath_2 Member Posts: 52
    Air Duct Calculator
    Just ordered one from ICP - International Comfort products.
    It is kisted under the Fast Parts program. Part # 2146347.
    Hope this is of some help.
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Try...
    http://firedragonent.com/ductalator.htm
    Doesn't work with www. for some reason
  • Mitch_4
    got it.
    thx
