Painting Radiators
i need to replace one, and i have one that has been the the garage and needs some painting. these are steam radiators. i know they sell high heat spray paint, but i was hoping to do it purple or yellow since it is going in my daughters room.
  • Adam_11
    Adam_11 Member Posts: 23
    Painting Radiators
    What would be the best type of paint and primer for painting old cast iron radiators?.Are there any brands that any of you would endorse? .
  • Dan Goodridge
    Dan Goodridge Member Posts: 62
    The best method is to have the radiator bead blasted. Oil based primer and oil base finish. Spray application is the best method. Hi temperature ( ie stove paint or automotive engine paint is not necessary )
    Dan Goodridge
  • Kevin_in_Denver_2
    Kevin_in_Denver_2 Member Posts: 588
    Silver seems to be the most popular color, but thermally the worst choice.
    Flat black radiates the most heat
  • Dave Stroman
    Dave Stroman Member Posts: 765
    Hi Kevin in Denver, this is Dave in Denver. Just wondering who you are.
    Dave in Denver
  • Bob Eh?_2
    Bob Eh?_2 Member Posts: 42
    I believe the definitive answer on radiator paints given by Dan himself lives here:
    http://www.heatinghelp.com/newsletter.cfm?Id=38
  • Phil_8
    Phil_8 Member Posts: 42
    Painting CI Rads
    There is a local shop that will paint CI rads but there most expensive finish is where they remove all of the paint, and wire brush all of the surfaces. Then they apply a laquer clear coat. The CI Rads end up with a very rich looking chest-nut brown appearance. I would like to know how much, if andhy, that clear coat finish reduces the heat emitting performance over say a flat black paint?
