Painting Radiators
Anthony Hill_2
Member Posts: 1
i need to replace one, and i have one that has been the the garage and needs some painting. these are steam radiators. i know they sell high heat spray paint, but i was hoping to do it purple or yellow since it is going in my daughters room.
Painting Radiators
What would be the best type of paint and primer for painting old cast iron radiators?.Are there any brands that any of you would endorse? .0 -
The best method is to have the radiator bead blasted. Oil based primer and oil base finish. Spray application is the best method. Hi temperature ( ie stove paint or automotive engine paint is not necessary )
Dan Goodridge0 -
Silver seems to be the most popular color, but thermally the worst choice.
Flat black radiates the most heatThere was an error rendering this rich post.
Hi Kevin in Denver, this is Dave in Denver. Just wondering who you are.
Dave in DenverThere was an error rendering this rich post.
I believe the definitive answer on radiator paints given by Dan himself lives here:
http://www.heatinghelp.com/newsletter.cfm?Id=380 -
Painting CI Rads
There is a local shop that will paint CI rads but there most expensive finish is where they remove all of the paint, and wire brush all of the surfaces. Then they apply a laquer clear coat. The CI Rads end up with a very rich looking chest-nut brown appearance. I would like to know how much, if andhy, that clear coat finish reduces the heat emitting performance over say a flat black paint?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
