Gas pilot nut wrench?
Bob Harper
Member Posts: 1,112
John L Leavey Co. Tons of goodies.
HTH
HTH
Gas pilot tube nut wrench?
Does anyone know where I can get a small wrench for the pilot tube nuts on the pilot tube from the gas valves on furnaces,water heaters,boilers?Sometines the nuts are really hard to get a normal open ended wrench or pliers on.Thanks,Ted0 -
I found ,
A thin walled "flarenut wrench" at Sears a couple years back. It has a 7/16ths side and a 3/8 for thermocouples. Chris0 -
Hey thats My
Gas valve wrench Chris. 3/8 X 7/16 open end at Sears. J.Lockard0 -
Jim,
This is a flare nut wrench, that is closed on 5 of the 6 sides.(open enough to fit over the connected tubing) Nice thing to have when you can find a thin walled version, but quite useless when some gorilla has been on any of the nuts with a channel lock or rounded it off with an adjustable wrench. Chris0 -
pilot wrench
its called a line wrench. its available at automotive tool supplys such as mac or snap-on0 -
pilot wrench
pilot wrench
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
