The look of 21st Century Steam Heating
Mad Dog_2
Member Posts: 8,413
sounds great. mad dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=210&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Neat, clean, modern, efficient....and.................
not to shabby looking either, huh? I wasn't crazy about the vent tapping height, but it didn't matter...she heated up faster and more thoroughly than any other steam rad I've seen. This radiator was a Steamview Radiator. Mad Dog
Looks good!
Just goes to show that rads aren't all Victorian fantasies, or utilitarian blocks of iron. That would compliment any modern home. Good job, dawg! How's the little one doing?0 -
Purty
Real Purty Matt!0 -
Where did you get it?
Is there a website to check out?0 -
Ditto on every point
A very nice hook-up indeed. It made my head turn.0 -
Yep I really like it too
Like her two older siblings...collicky as he--, but otherwise very healthy. Thanks Bill. Here she is with Grandma Mad Dog
msybe a hundred years from now....
it will be in your musuem. Mad Dog
Steamhead looked it up for me
Steamview Radiator company. I'll find it fior ya. MD
For the thin'-look
It was quite chunky and really cranked out the steam. This one was rated for 3500 btus. MD
Nope that address doesn't work
Purdy baby pic though. I bet she "really cranks it out" too.0 -
Try....
www.steamradiators.com. A small subsidiary of Runtal, based in Ward Hill Ma. Nice stuff and like Matt said, they really crank. Chris0 -
That worked THanks guys
Looks like \"big\" sister is checking...
to make sure Grandma is holding baby sister properly! That's a geat picture, Matt.0 -
supply tapping
Hi MD,
What size is the supply outlet? It looks like you used a concentric fitting to increase to the supply valve size.
The radiator is attractive, for those that like the modern look. I'll check out the website.
Thanks for sharing.
Best regards, Pat0 -
MD and Boilerguy,
I have used a few of these and was amazed at the output. For trimming them out, I went with Tunstall products. They make real nice accoutriments to accentuate the attractiveness of the units.(chrome, nickle and otherwise)
Just make sure you get them in BEFORE the walls are finished!!!! (don't ask me how I know this NOW) Chris0 -
Nope
They are 1"...but everything is so sleek it looks that way. I brought 1" up to it and had to use a 1" brass street 45 because the pipe needed to slip past a floor joist. Mad Dog
now thats sweet..
very nice looking..gwgillplumbingandheating.com
I hear ya....
It went in after the fact because I didn't want it getting painted and spackled. I was by myself, so it took a little longer, but it was not much harder than mounting a panel radiator...more places to grab actually... yep, I hop eto put some more of these in, but they are pricey! Maybe, the company can give us a contractors discount? Mad Dog
Yep...Monika Rose in her Cinderella outfit
MD
Is that a 1" brass street 45?0 -
Tis isn't it?
Boy, I didn't know how big this would go over. Its about time someone made one of these huh? Mad Dog
Steam Radiators
Thank you for your feedback regarding Steam Radiators. The sleek profile of Steam Radiators frees up valuable floor space for your customers. Steam Radiators work with both one and two pipe steam systems and outputs range from 2,564 to 13,962 per unit. Steam Radiators are available for immediate delivery and contractor discounts are offered direct from our factory in Massachusetts. For more information please go to our website: www.steamradiators.com or call 1-800-966-05870 -
Thanks Owen.
Like I said, I've used a few as replacements and have been more than satisfied.
I was very impressed with the output of such a sleek and small unit!During the install I was worried that they may not be enough for all the glass in the room. When the owner called and said they were too hot I immmediately decided to go with steam TRV's. (She wasn't too keen on them because of the cost....)and it hasn't happened yet.
For all....They can be piped and arranged in most popular steam configurations. One pipe, two pipe are not a problem. With a bit of work, they can be mounted vertically also. This is how the bigger ones I used were mounted. Nice stuff ! Chris0 -
Steam Radiators
In addition to the contemporary Steamview, Steam Radiators also makes a sleek classical looking radiator, the Charlston Pro. Check this out also on www.steamradiators.com.
Owen0
- 167 Indoor-Air Quality
