multiple temperatures
jhansen
jhansen Member Posts: 59
i am installing a w/m ultra boiler which serves an indirect fired water heater, a high temperature baseboard zone and various radiant running at 115 degrees. any suggestions on the best way to get my mixing done. I am utilizing primary secondary.
thanks jh
  • hr
    hr Member Posts: 6,106
    How much do you want to spend?
    > primary secondary.
    > thanks jh
  • hr
    > primary secondary.
    > thanks jh
  • hr
    A simple method would be to use the outdoor reset feature for the high temperature and install a manual 3 way mix valve that tracks along with the reset curve, for the radiant temperatures.
    That boiler has a DHW priority, built into the board, to handle DHW. Pipe it (the DHW circ) as a seperate loop off the additional tappings. Be sure to use flow checks, or check flanges on both circs. I think the installation manual shows some piping options for what you are trying to do.
    The on board control may run two temperatures? I have not gotten into tha control that deep?
    Design your high temperature loop to meet the load with the lowest possible temperature. It may be possible to beef up the baseboard lengths or higher output board to run lower temperatures at design day. The lower the operating temperature the more efficient a condensing boiler operates. Any way to design the high temperature loop emitters at around a 140°F supply :)?
    That's an expensive boiler to run a 180° system, if that is what is really needed.
    hot rod
