air elimination
chuck_6
chuck_6 Member Posts: 107
Go to the Gorton website. It is www.gorton-valves.com. You can also speak to Ken Kunz at (908) 276-1323. Gorton makes terrific air and main vents. I highly recommend them. Ken is the expert and now may be time to switch some out, ahead of the next cold season.
  • Ken Carson
    Ken Carson Member Posts: 2
    air elimination
    Where can I find info to help my customers understand the importance of air elimination.
    I had 2 plumbers come in behind me and say the system is ok with the little silver vents and no air seperator.
  • WPH2205
    WPH2205 Member Posts: 52
    Bell & Gossett has a good manual on air separation.
  • Jed_2
    Jed_2 Member Posts: 781
    More info
    many boilers have built in air separators. Every system does not need a spirovent type air separator. How is it piped? What's the boiler? Who's autovent is installed? Where are they in the system? More info.
    Jed
    Steamhead Member Posts: 18,211
    Is this
    a steam or hot-water system? I've heard vents for both types described as small and silver.......
    Consulting
  • Jerry Boulanger_2
    Jerry Boulanger_2 Member Posts: 111
    Here's a link
    to an article on the B&G web site.
    http://www.bellgossett.com/Press/proper.htm
    Auto air vents in water systems only work when they are installed on an air separation device like an air purger or a boiler chest where the flow velocity is low. Otherwise they typically only vent air when the pump is off.
