Weird Amana hydronic heater
John Owens
John Owens Member Posts: 5
I came across an outdoor hydronic heater filled with glycol. I had heard of such beasts - but never seen one. The unit fires, the circulator fan unit is running - it does not circulate. The resivoir is full of glycol, and I hear lots of gurgling when I turn the power off. Any one have some hints?
  • 2 guesses
    Airbound or pump impeller worn out.
    The pump and fan were on the same motor, so the pump shaft is spinning.
    That thing has outlasted ALL expectations of it. It might be time to replace the thing.
    Noel
  • clammy
    clammy Member Posts: 3,232
    long time
    It's been about 15 years since i worked on one a real pain and i believe if i remenber right that pump is a little hard to remove the ho exclaimed how low there ulitily bills where but they wheren,t to happy about the service bill .The system i worked on also had a secondary fan coil working off the maain unit in the basement 4 story condo a real beauty best of luck peace clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
