Circ LED Lights
hr
Member Posts: 6,106
were mislabeled in the catalog and online. This number used to appear as a 12V but is in fact 120 volt.
Johnstone Supply has some a bit smaller in diameter, but only in red.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Circ LED Lights
A while back one of the guys showed how he had found a LED light to add to the side of a grunfos pump to show that it had power.I believe he got it from Radio Shack.I've only been able to find 12v but not 120v.If someone has the part number or another source that would be great.
Thanks
Dobber0 -
here is the green one's part number
120-Volt Neon, Green
$3.29
Catalog #: 272-708
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
pressure gauges better
The green diagnostic light is nice, and will tell you if you have 120 volts to the pump, but will not guarantee the pump is working. A pressure gauge up, and down stream will be a better indicator of a pump that is working. Now you can even plot the pump on its curve and have an idea of performance. As Dan Holohan would say Save the money, and put it towards the beer
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0
- 167 Indoor-Air Quality
