Circ LED Lights
hr
hr Member Posts: 6,106
were mislabeled in the catalog and online. This number used to appear as a 12V but is in fact 120 volt.
Johnstone Supply has some a bit smaller in diameter, but only in red.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Brian
    Brian Member Posts: 285
    Circ LED Lights
    A while back one of the guys showed how he had found a LED light to add to the side of a grunfos pump to show that it had power.I believe he got it from Radio Shack.I've only been able to find 12v but not 120v.If someone has the part number or another source that would be great.
    Dobber
  • gerry gill
    gerry gill Member Posts: 3,083
    here is the green one's part number
    120-Volt Neon, Green
    $3.29
    Catalog #: 272-708
    gwgillplumbingandheating.com
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    pressure gauges better
    The green diagnostic light is nice, and will tell you if you have 120 volts to the pump, but will not guarantee the pump is working. A pressure gauge up, and down stream will be a better indicator of a pump that is working. Now you can even plot the pump on its curve and have an idea of performance. As Dan Holohan would say “Save the money, and put it towards the beer”
    Taco, Inc.
    Joe Mattiello
    Technical Service Technician
    joemat@taco-hvac.com
    401-942-8000 X 484
    www.taco-hvac.com
    Joe Mattiello
    Taco Comfort Solutions
