Cool Tool
gerry gill
Member Posts: 3,083
to the heatinghelp tools section..along with the pump indicator lites you found.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
Trying to locate these in the US
http://www.geonordic.se/page9.html
This is a pretty handy little tool.
Small, wet-rotor, PSC (permanent split capacitor) pumps are not known for their low-end start up torque. After sitting idle (systems without pump excercising) through the cooling season the impeller can "freeze" up. This would be handy tool for identifying these "lock-ups". The pump will still have a correct voltage reading, but will not be moving any fluid.
Anyone know of anywhere in the US I can get a couple of these? I emailed this company in Sweden but have not received a response as of yet.
Regards,
PR
Grundfos
Pauli,
Grundfos has them. In fact, I have a spare one on my desk. If you can't get it from Grundfos, let me know and I'll send it to you.
I bet you your local Grundfos Guy has a whole Box of them. If you need more, I know where and how to source some.
Take care Bud,
Mike0 -
almost forgot......
....those will not work on all Circs. I know that those A.C. Indicators (as they are called) dont work on all TACO Pumps, for example. It always depends on the construction, I think.
Again, hope this helps.
Mike0 -
Yea
We have them also, they work great for Gundfos pumps.
Mikes right, not so good for others
Scott
They work!
on Grundfos and B&G wet rotor pumps. as well as solonoid valves. Able Distributors in Chicago also had a bunch made with their logo.
I suggested a heatinghelp.com version a while back
hot rod
Paul did you try ...................
Viessmann thats where I got mine. I also got a quote from the manufacturer but found them a little pricey. I think they were about $4.00 per unit (US) with 500 units ordered plus setup and artwork charges. John@Reliable0 -
I have a couple of these Grunfos tools. But you have to realize that they indicate voltage, not rotation. They will spin whether the pump is locked up or not.
Dave in DenverThere was an error rendering this rich post.
- 167 Indoor-Air Quality
