Cool Tool
gerry gill
gerry gill Member Posts: 3,083
to the heatinghelp tools section..along with the pump indicator lites you found.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
  • Paul Rohrs_4
    Paul Rohrs_4 Member Posts: 466
    Trying to locate these in the US
    http://www.geonordic.se/page9.html
    This is a pretty handy little tool.
    Small, wet-rotor, PSC (permanent split capacitor) pumps are not known for their low-end start up torque. After sitting idle (systems without pump excercising) through the cooling season the impeller can "freeze" up. This would be handy tool for identifying these "lock-ups". The pump will still have a correct voltage reading, but will not be moving any fluid.
    Anyone know of anywhere in the US I can get a couple of these? I emailed this company in Sweden but have not received a response as of yet.
    Regards,
    PR
  • hydronicsmike
    hydronicsmike Member Posts: 855
    Grundfos
    Pauli,
    Grundfos has them. In fact, I have a spare one on my desk. If you can't get it from Grundfos, let me know and I'll send it to you.
    I bet you your local Grundfos Guy has a whole Box of them. If you need more, I know where and how to source some.
    Take care Bud,
    Mike
  • hydronicsmike
    almost forgot......
    ....those will not work on all Circs. I know that those A.C. Indicators (as they are called) dont work on all TACO Pumps, for example. It always depends on the construction, I think.
    Again, hope this helps.
    Mike
  • ScottMP
    ScottMP Member Posts: 5,882
    Yea
    We have them also, they work great for Gundfos pumps.
    Mikes right, not so good for others :(
    Scott
  • hr
    hr Member Posts: 6,106
    They work!
    on Grundfos and B&G wet rotor pumps. as well as solonoid valves. Able Distributors in Chicago also had a bunch made with their logo.
    I suggested a heatinghelp.com version a while back :)
    hot rod
  • John@Reliable_10
    John@Reliable_10 Member Posts: 99
    Paul did you try ...................
    Viessmann thats where I got mine. I also got a quote from the manufacturer but found them a little pricey. I think they were about $4.00 per unit (US) with 500 units ordered plus setup and artwork charges. John@Reliable
  • Dave Stroman
    Dave Stroman Member Posts: 765
    I have a couple of these Grunfos tools. But you have to realize that they indicate voltage, not rotation. They will spin whether the pump is locked up or not.
    Dave in Denver
