MZ Boiler vs Rinnai
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
We've installed six of them and (knock on wood), they are all running fine; flawless.
The Rinnai is a LOT cheaper, but it's a water heater, not really meant for hydronic and it's not high efficiency. You would also have to use a high-head pump for proper flow through the heat exchanger which makes it less efficient.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
MZ Boiler vs Rinnai
I had to condemn a Hydropulse boiler today. Water is leaking into the combustion chamber (older model with the "bolted" section versus the newer units that are welded. This particular Hydropulse also heats Domestic h/w via a storage tank. I'm thinking of using a Rinnai wall-hung boiler to do both jobs but the customer is quizzing me on these MZ Boilers which I have never seen before.
ANY recommendations would be greatly appreciated.
Thanks,
Roy
Ontario, Canada0 -
By far
the MZ is a much more quality unit than the Rinnai, in my opinion. I have had a MZ in my shop, with a small flash DHW heater, it has performed flawlessly. A true condensing heater built with solid components. A great track record, with excellent support.
The Rinnai is pretty much an instantanous water heater, I believe. Different animal altogether.
hot rod
love my MZ
I have one in my house and a few in the field and it's a real winner. Built real well and trouble free0 -
MZ
THANKS Guyz..............looks like the MZ is a winner, hands down.
Roy
Ontario, Canada0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
