MZ Boiler vs Rinnai
We've installed six of them and (knock on wood), they are all running fine; flawless.
The Rinnai is a LOT cheaper, but it's a water heater, not really meant for hydronic and it's not high efficiency. You would also have to use a high-head pump for proper flow through the heat exchanger which makes it less efficient.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Roy_4
    Roy_4 Member Posts: 17
    MZ Boiler vs Rinnai
    I had to condemn a Hydropulse boiler today. Water is leaking into the combustion chamber (older model with the "bolted" section versus the newer units that are welded. This particular Hydropulse also heats Domestic h/w via a storage tank. I'm thinking of using a Rinnai wall-hung boiler to do both jobs but the customer is quizzing me on these MZ Boilers which I have never seen before.
    ANY recommendations would be greatly appreciated.
    Thanks,
    Roy
    Ontario, Canada
  • hr
    hr Member Posts: 6,106
    By far
    the MZ is a much more quality unit than the Rinnai, in my opinion. I have had a MZ in my shop, with a small flash DHW heater, it has performed flawlessly. A true condensing heater built with solid components. A great track record, with excellent support.
    The Rinnai is pretty much an instantanous water heater, I believe. Different animal altogether.
    hot rod
  • Phil_6
    Phil_6 Member Posts: 210
    love my MZ
    I have one in my house and a few in the field and it's a real winner. Built real well and trouble free
  • Roy_4
    MZ
    THANKS Guyz..............looks like the MZ is a winner, hands down.
    Roy
    Ontario, Canada
