kitec pipe failure
mark_41
Member Posts: 48
the latest skuddlebut is kitec has indicated that water acidity could be a problem. ph is 6.5-8.5
Kitec pipe failure
Hi Wallies! I've been pretty busy lately and missed some of the Kitec pipe failure info. What was determined? Thanks in advance!! We use this product extensively and have had no problems as of yet!!0 -
Steve Gates
posted this on May 9:
"I talked to one lf there reps at Radfest. he said 7 labs 7 results on the washington stuff. I gave him a 3/4 coupling I'd cut out because of split at the ring. Waiting to see? He thinks someone crimped it to tight? Who ever did that job also didn't support it well,12 ft and no hanger."
That's the latest.Retired and loving it.0 -
Thanks Dan!!0 -
radfest
> "I talked to one lf
> That's
> the latest.
radfest
who is radfest?0 -
kitec
> "I talked to one lf
> That's
> the latest.
not who but what. rpa's version of wetstock0 -
What do they want
PH-wise, what do they want to see as far as PH is concerned in their tube?0 -
acidity
I don't see where acidity would be a problem unless the PEX inner liner was defective???0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
