kitec pipe failure
mark_41
mark_41 Member Posts: 48
the latest skuddlebut is kitec has indicated that water acidity could be a problem. ph is 6.5-8.5
  • mike glass
    mike glass Member Posts: 53
    Kitec pipe failure
    Hi Wallies! I've been pretty busy lately and missed some of the Kitec pipe failure info. What was determined? Thanks in advance!! We use this product extensively and have had no problems as of yet!!
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,732
    Steve Gates
    posted this on May 9:
    "I talked to one lf there reps at Radfest. he said 7 labs 7 results on the washington stuff. I gave him a 3/4 coupling I'd cut out because of split at the ring. Waiting to see? He thinks someone crimped it to tight? Who ever did that job also didn't support it well,12 ft and no hanger."
    That's the latest.
    Retired and loving it.
  • mike glass
    Thanks Dan!!
  • mark_41
    radfest
    > "I talked to one lf
    > That's
    > the latest.
  • mark_41
    radfest
    who is radfest?
  • mark_41
    kitec
    > "I talked to one lf
    > That's
    > the latest.
  • steve gates
    steve gates Member Posts: 329
    not who but what. rpa's version of wetstock
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    What do they want
    PH-wise, what do they want to see as far as PH is concerned in their tube?
  • mike glass
    acidity
    I don't see where acidity would be a problem unless the PEX inner liner was defective???
