Vitodens neutralizer kit
Matt_21
Matt_21 Member Posts: 140
neutralizer kit for the vitodens or do you just make them yourself. if homemade, i'd like a picture if you have one available.
  • Constantin
    Constantin Member Posts: 3,796
    Do a search...
    ... and you will find several home-made on this site, complete with pictures.
    I believe Mike T. from Swampeast MO has one made of a tupperware box + a rain sensor (to track condensate), others used similar containers and limestone or marble chips to prevent their cast iron mains from being rotted out.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    This one's really much larger than necessary, but it's in a basement that will never be finished. Two PVC pipes you see are for the rainfall sensor to dump water (it pivots from side-to-side).
    Made the drain connection with a ¾" PVC male adapter, two rubber o-rings, two flat galvanized washers and a ¾" conduit nut. No leaks.
    Used 5-gallon bucket of ¼" crushed limestone from the local quarry. Should take a LONG time to dissolve that much stone.
    Not as pretty as the Viessmann unit, but at about $20 cost (limestone was free), I won't complain.
  • BIG V's neutralizer
    It's not that expensive. $45.00 or less. I've made a few of my own but, no more. Why bother? Theire's is a whole lot better looking than what I've made. To each their own.
