Does tankless for baseboard on steamer require circulator>
Steve Garson
Steve Garson Member Posts: 191
Close to finishing a new steam boiler installation with a 4-section WM. The small (13,000 BTU heat loss) and 33 feet baseboard) loop will be installed to a 6GPM Everhot vertical tankless connected to the steam boiler.
Will the pipiing between the boiler and tankless require a circulator, or will will convection be adequate?
