carrier boilers
David_5
Member Posts: 250
Rest assured it is someone elses boiler with the Carrier name on it.
David
David
has any one installed these
carrier air conditioning makes a boiler. has any one installed these with success, they look very pretty to the eye0 -
If I'm not mistaken
Dunkirk makes them and badges them for Carrier.0 -
Yep
Always was Dunkirk, unless they have someone else make them now0 -
Who makes Carrier?
I just bid on a job and the other bidder was using a Carrier with "titanium burners"( whoop-tee-do ) the home owner was fixed on that, more to boilers than just the burner, any way I talked to my rep and he said that Utica makes the cast for Carrier. I asked who locally sells them so I could give a apples to apples bid but he said that Sears is the only one that sells them that he knows, he locally reps Utica and I didn t look into it any further.
This was the second time that I have run into a contractor offering Carrier.
Don
If you see
a boiler with Lennox, Bryant or Carrier label, it was made by Dunkirk. The Utica is news to me, but I will check with our Bryant/Carrier supplier. Greg0 -
ECR International
owns both Utica and Dunkirk, so they share product lines also.0 -
Also
If I am not mistaken,...United Technologys owns Carrier and They have also purchased ICP, International Comfort products/ Which deals with the dunkirk Line. ICP is a Heil, Temp-Star, Air Quest dealer. Also carry Utica/Dunkirk Weil Mclain boilers......0
- 120 Geothermal
