Add a hydronic loop to existing hw baseboard?
Tom Macintosh
Member Posts: 3
I would like to add a hydronic loop to my existing hot water baseboard system. The current setup is a Taco 007-BF5-J (1/25 hp) circulator serving three zones of ¾ copper baseboard, (50, 75 and 75 loops). The Sentry S-90 (90K input) boiler has worked great since I installed it 2 years ago. I just finished remodeling the kitchen, dinning area and powder rooms. My wife did not want me reinstall the HW baseboard in these areas, so I thought I could use an under floor loop of PEX to heat these areas. I plan to use a Taco 0010-F3 (1/8 hp) circulator and a tempering valve to limit input temperature to the 250 loop. In order to hook up the tempering valve properly, I will need a cold leg at higher pressure than the return side. I plan to have both pumps discharge through flow checks into the boiler, with a tap for the tempering valve. I had a friend look at the drawing, and he thought that the more powerful pump would force the check valve closed on the weaker one. I think that the high head pump is required for the PEX loop, but if I used a similar pump on the HW baseboard, it would be noisy.
can you split the loop
Can you make the floor heat into two small loops. then you can use a smaller pump.0 -
A number of ways to tie radiant
into a baseboard loop. Sounds like a bit much pump for the job, to me. Did you do a design calc bases on needed btu output? or how did you come up with that pump selection?
Check out this aretice for some ideas also.
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,62497,00.html
hot rod
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
