Job pics
Jeff Elston
Jeff Elston Member Posts: 289
Frankie great work
I have been using Gruvlok made by Anvil, I found them to have a longer list than Vic. A few more options
I just used some of there copper stuff,
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=405&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • FRANK_24
    FRANK_24 Member Posts: 80
    JOB PICS
    This job is for a senior citizen residence on Long Island. The removal was twin 14 section 4500 series Mills boilers. The new boilers are Burnham steel 80 HP each. There are four indirect water heaters, 100 gal each, and five expansion tanks. We cut in valves and Tees all over the place to accomodate a temp boiler in a trailer while the install was going on.
  • Al Corelli_2
    Al Corelli_2 Member Posts: 395
    Nice Work!
    I miss those mid size jobs.
    The insulation on the piping is really nice. Painting the boiler room is also a great detail.
    Al Corelli
    NY
  • very nice work
    Great job. Big improvement from what was there last. How are you controling those boilers? Tekmar or some other type of staging control? The insulation makes the job look very clean. Thanks for the pics.
  • mikea23
    mikea23 Member Posts: 224
    looks good
    I also like the insulation
    where is a good place to purchase it
  • Jeff Elston
    Nice
    Nice looking job Frankie, What kind of gruv material do you use?
    I am loving it
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Very Good !!!
    Frankie, Thats a great Job !! looks like you guys realy like what you do, Bet that will set the heating bill back a bit !
    David
  • FRANK_24
    RE: ABOVE
  • FRANK_24
    RE: ABOVE
    These three boilers are maintaining 180* for DHW, while the heating side is tempered via a four inch three way valve mixing cooler return with hot supply water. The temperature of the water is controlled by a heat timer set back. We installed a blending pump on each boiler to prevent condensation or shock. Since this was a NY State job, the contract called for painting which we did in hopuse and the insulation was installed by a sub contractor know only as "Gumbs". But I do admit that the paint and insulation do polish up the job. We used Victaulic fittings w/ schd 40 pipe on the header. As you see we used plenty of swing joints. A few fittings were welded near the six inch Air Eliminator Thanks for all your comments. Last week we started 175 HP Scotch Marine steam replacement. I'll be posting when that is completed.
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Beautiful Job, Frankie
    Were you in charge of the entire job? I mean, the lighting itself gets an Academy Award. That layout and final installation is as good as we tend to see on our specified jobs but I think yours would have a shorter punchlist... :)
    And you call yourself "just a plumber".... Yeah, Right!
    Brad
  • steven E.HEAT
    steven E.HEAT Member Posts: 47
    OUTSTANDING!!!!!!!!!!!!!!!
    HERES A MAN WHO LOVES WHAT HE DOES! well done.
  • FRANK_24
    LIGHTS, CAMERA, ACTION
    > And
    > Right!
    > Brad
  • FRANK_24
    The lighting installation was directed by myself. The state wanted more lights, so I gave it to 'em. The header design and material placement was my idea. My boss gives me free reign on these jobs as long as I bring 'em in under budget. BTW, the valve chart that I provided listed 72 valves. [I didn't get all of 'em either] And to Steven, yeah I like my job.
  • Brad White_9
    You did this as Public Work?
    Dang, Frankie. You put a lot of Lowest Qualified Bidders to shame. The taxpayers should thank you. More should follow your lead. You did great, even to the lighting. Safe and worth showing off too. Impressive.
  • gerry gill
    gerry gill Member Posts: 3,083
    very impressive!!
    i like this install alot..thanks for posting pictures..very nice work.
    gwgillplumbingandheating.com
  • Boilerpro_5
    Boilerpro_5 Member Posts: 407
    Really Nice!!!
    I don't do big work like that around here (a heating plant that size would heat most towns around here), but that's really nice work. Not ony do you like your job, it appears you know what you're doing!
    Boilerpro
    EBEBRATT-Ed Member Posts: 19,606
    Really nice job, Frankie but you already kno that cause your a pro.
    One question. The gas piping outside looked like galvy. Do they allow that in NY??????????
    Ed
  • FRANK_24
    GALV GAS PIPING
    Here on Long Island, since time immortal, the local gas utility has mandated that all outside gas piping be galvanized. Now, if you cross that invisible line in the dirt, and cross over from one county to another and wind up on NYC property, AND if you put in galvanized pipe for gas usage, the LAW will come down on you as if you committed the crime of the century. Ahhh the plumbing codes, mis-written by few, ignored by many.
