Polybutylene pipe connections
Bob Forand
Member Posts: 305
Sioux Chief makes and most wholesalers can sell a pex to poly crimp fitting...
I have several large condo projects inmy area and all were plumbed with polybutylene "gear plastic" does anyone have a fitting they have found that works well to join to copper or a brand of pex?
What about the new "Sharkbite" fittings?
www.cashacme.com
I have seen them but was not sure if they worked on polybutylene
The "guy at the counter" claims they work with EVERYTHING. I have never used them.
Any reviews out there?????
poly 'b' to pex/copper
we use a pex to poly coupling kit that comes with a pex crimp ring & a poly crimp ring, & uses the pex crimp tool for both rings. No problems yet. (3 years) Should be available @ your supplier.0 -
sharkbite fittings
We have been using these fittings for a few months now. They work great. So far I have only used them to join PB to copper. As long as the o.d. of the tubing is the same as copper they should work. Much quicker and you don't have to worry about the nuts cracking on the Qest couplings.
jbplumber0 -
I second Sioux Chief
they make a transition fitting. Or but a pex to copper adapter and a PB to copper adapter and solder them together.
I'm not sure about the Shark attack fittings. Seems PB can be egg shaped ir it was rolled off a coil. It is a much thinner wall than pex. Would that Shark fitting accomodate this? Hate to learn the hard way. I know crimp fittings hold
hot rod
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
