Help with steam with a hot water loop
U2WATCHER
Member Posts: 9
I HAVE A CUST WITH A HOT WATER LOOP.A VERY OLD BOILER,WELL NOW THE BOILER IS CRACKED AND IM TOLD BY MY ASSOC. THAT IT WILL VOID THE WARRANTY IF I REINSTALL IT THIS WAY. ANY SUGGESTIONS GUYS
Steam w/ HW loop
I have seen these systems work successfully without harm to the steam boiler. The warranty is a different issue. You should check with the manufacturer before deciding. Proper piping of a steam boiler is essential for a long life. Most steam boiler failures are due to improper piping. I have come across many steam boilers that are 30+ years old. Adding a baseboard loop or a radiant loop is feasible, but precautions should be taken: heat load, temperature protection, proper use of controls.0 -
water loop off steamer
the best advise I can give is to use a plate heat exchanger or a small everhot. This will protect the boiler and should not jeapardize any warrantee, but as posted previously, check with you manufacturers rep.
- 109 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
