Help with steam with a hot water loop
U2WATCHER
U2WATCHER Member Posts: 9
I HAVE A CUST WITH A HOT WATER LOOP.A VERY OLD BOILER,WELL NOW THE BOILER IS CRACKED AND IM TOLD BY MY ASSOC. THAT IT WILL VOID THE WARRANTY IF I REINSTALL IT THIS WAY. ANY SUGGESTIONS GUYS
  • brad rutherford_2
    brad rutherford_2 Member Posts: 10
    Steam w/ HW loop
    I have seen these systems work successfully without harm to the steam boiler. The warranty is a different issue. You should check with the manufacturer before deciding. Proper piping of a steam boiler is essential for a long life. Most steam boiler failures are due to improper piping. I have come across many steam boilers that are 30+ years old. Adding a baseboard loop or a radiant loop is feasible, but precautions should be taken: heat load, temperature protection, proper use of controls.
  • Al Letellier
    Al Letellier Member Posts: 781
    water loop off steamer
    the best advise I can give is to use a plate heat exchanger or a small everhot. This will protect the boiler and should not jeapardize any warrantee, but as posted previously, check with you manufacturers rep.
