hot water from AC
Carl PE
Member Posts: 203
It's called a de-superheater. A quick google search should give you a few manufacturers.
You should probably have it installed by whoever did your a/c to avoid any warranty issues. Also, keep in mind you have to disconnect the water in the wintertime.
hot water from AC
A friend of mine has a device that captures the heat from his air conditioning compressor to make hot water. Does anyone know where to get one?0 -
From York, PA
this was in a trade mag recently. I have also seen them in food service operations.
hot rod
American Energy products
We recently moved and one of the things I reall miss is my desuperheater. We used it for 10 plus years, never turning on the gas to the water heater whenever the AC was on.
The people in the subject line are the ones that I got mine from, the Aquefier. Trevor Martin Company, out of Clearwater, Florida are the reps. The number I have for them is 727.573.1490. As I recall, I got mine through United Refrigeration.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 983 Plumbing
- 389 Solar
