hot water from AC
Carl PE
Carl PE Member Posts: 203
It's called a de-superheater. A quick google search should give you a few manufacturers.
You should probably have it installed by whoever did your a/c to avoid any warranty issues. Also, keep in mind you have to disconnect the water in the wintertime.
