Something new down below (Dan H.)
Ted_4
Ted_4 Member Posts: 92
Yes, I just got it. Thanks, Dan. First UP then DOWN. Phew, I'm glad that's over. Score another one for the computer-challenged!
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,535
    Professor Eugene Silberstein
    has agreed to be the Wall's resident air conditioning and refrigeration guru. To open that room go to Options and click on the Professor's forum. There's nothing the Professor doesn't know about air conditioning and refrigeration. Ask away!
    In adding the new room, Invision clicked a switch that shouldn't have been clicked and that's the reason why the software has been asking for user names and passwords. They're fixing that even as I type. Sorry for the inconvenience.
    Retired and loving it.
  • Kal Row
    Kal Row Member Posts: 1,520
    that option did not come up up yet
  • DanHolohan
    Have you gone to Options
    and checked the Professor Silberstein Forum box? If you have, refresh your screen and scroll to the very bottom of the Wall. You'll see it there.
  • Empire_2
    Empire_2 Member Posts: 2,343
    No Dice
    I am not seeing it either Dan. Cheched the box and refreshed, but nothing in the list.
  • Kal Row
    ok - go it, you need to first close iexplorer completely..
    to clear it's cache, so that it reloads the forum's dialog box correctly with the new checkbox - some browsers have options to "delete all private data" which would also work
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    Welcome!
    Thanks for the opportunity, Dan!
  • Ted_4
    Options?
    Exactly where is "options" supposed to appear? The screen doesn't look any different that it ever did.
  • Ted_4
    Persistance
    > ever did.
  • DanHolohan
    Ted, look up
    Do you see that orange bar that runs along the top of the Wall? It reads Exit, New Messages, Search, OPTIONS. Click Options and then put a check mark next to Professor Silberstein's box, which you'll find under Forums. Once you've done that, refresh your screen and scroll to the bottom of the Wall. You should have it then.
