Something new down below (Dan H.)
Ted_4
Member Posts: 86
Yes, I just got it. Thanks, Dan. First UP then DOWN. Phew, I'm glad that's over. Score another one for the computer-challenged!
Professor Eugene Silberstein
has agreed to be the Wall's resident air conditioning and refrigeration guru. To open that room go to Options and click on the Professor's forum. There's nothing the Professor doesn't know about air conditioning and refrigeration. Ask away!
In adding the new room, Invision clicked a switch that shouldn't have been clicked and that's the reason why the software has been asking for user names and passwords. They're fixing that even as I type. Sorry for the inconvenience.
Retired and loving it.0 -
that option did not come up up yet
Have you gone to Options
and checked the Professor Silberstein Forum box? If you have, refresh your screen and scroll to the very bottom of the Wall. You'll see it there.Retired and loving it.0 -
No Dice
I am not seeing it either Dan. Cheched the box and refreshed, but nothing in the list.0 -
ok - go it, you need to first close iexplorer completely..
to clear it's cache, so that it reloads the forum's dialog box correctly with the new checkbox - some browsers have options to "delete all private data" which would also work0 -
Welcome!
Thanks for the opportunity, Dan!0 -
Options?
Exactly where is "options" supposed to appear? The screen doesn't look any different that it ever did.0 -
Persistance
> ever did.
Ted, look up
Do you see that orange bar that runs along the top of the Wall? It reads Exit, New Messages, Search, OPTIONS. Click Options and then put a check mark next to Professor Silberstein's box, which you'll find under Forums. Once you've done that, refresh your screen and scroll to the bottom of the Wall. You should have it then.Retired and loving it.0
