JASS by K-Tam Indirect Water Heaters
Boilerpro_3
Boilerpro_3 Member Posts: 1,231
This is not my work, but I certainly wouldn't mind claiming it! I am looking at making a couple of changes to eliminate some heavy venting system corrosion which is very common with the Lochinvar Mini's. I suspect it is from short cycling and I need to add some mass to the boiler loop....Possible the Indirect heater.
Thanks all
Boilerpro
  • rb_6
    rb_6 Member Posts: 222
    K-Tam
    Last I had heard (1995), Raymond Tam had left the country after a series of ...lets just say interesting events...
    Allied Engineering (Superhot) from Vancouver, B.C., I believe bought some of the assets.
  • Brad_3
    Brad_3 Member Posts: 24
    It's now Advanced Metalpres Inc. in Coquitlam BC Canada. 604-528(6?)-8268
    What I've seen is good stainless tanks with sub-standard insulation.
    Brad
