JASS by K-Tam Indirect Water Heaters
Boilerpro_3
Member Posts: 1,231
This is not my work, but I certainly wouldn't mind claiming it! I am looking at making a couple of changes to eliminate some heavy venting system corrosion which is very common with the Lochinvar Mini's. I suspect it is from short cycling and I need to add some mass to the boiler loop....Possible the Indirect heater.
Thanks all
Boilerpro
Thanks all
Boilerpro
K-Tam
Last I had heard (1995), Raymond Tam had left the country after a series of ...lets just say interesting events...
Allied Engineering (Superhot) from Vancouver, B.C., I believe bought some of the assets.0 -
It's now Advanced Metalpres Inc. in Coquitlam BC Canada. 604-528(6?)-8268
What I've seen is good stainless tanks with sub-standard insulation.
Brad0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
