Fast job
lchmb
lchmb Member Posts: 2,997
This old timer failed inspection by the state. Gee wonder why..You could actually see the flame through the front as it fired..
  • lchmb
    fast replacement
    We started at 11. Running by 4. Not exactly as I would have liked to pipe it (yes I agree with pumping away but couldn't fit the circ's in) but it works good..
  • Great job on the fly Lchmb
    We have a town where every house has a common supply that goes to the end of a finished basement , and comes back split into separate zones . No way to reverse it to have the pumps on the supply , so we install them on the return . As far as I know , there aint many airlock problems on the new install .
    One thing I would suggest with these tight installs is to use a zero clearance air separator ( we've been using B ang G , works great ) , or even rely on the built in air eliminator on the Weil . I think the built in does an excellent job on it's own . What kind of heat do they have over there ?
    Hey , 5 hours to install and you found time to raise it on blocks , keep every critical component accessible , pipe a thermal trap and mixer for the coil , and have everything level and square - what more could the homeowner ask for ?
  • eleft_4
    eleft_4 Member Posts: 509
    Nice job.
    Two things will make it easer to service. 1)Flex oil feed line. 2)A ball valve on the supply near the boiler.
    Again fine Craftsmanship,
    al
  • Weezbo
    Weezbo Member Posts: 6,231
    Hard for any argument by HO...no penalties :)
    only one itty bitty ?/ though..../ does the insulation stuffed in the chiminey feed the same L- vent?
  • lchmb
    Believe it or not
    Weezbo you have a heck of an eye. That opening is actually there for the two 150,000 BTU gas HW heaters. This pic is of the vent pipe which the caretaker decided to turn and end in the cellar (at least till I got there). That will be the next part of the project...:)
  • lchmb
    I agree with you
    But I was on a very slim budget for this one. We were actually only paid to replace the boiler itself. The owner wanted a simple one for one swap (how I have no clue). Being slightly stubborn I sort of broke the budget with the extra piping I did. As to flex line's, I would love to but again....:( I just do what the boss wants..
  • lchmb
    Coming from you
    That's a heck of a compliment. THanks Ron. As to the B@G..I'm still working on those (boss is stubborn). If you look I was actually forced to use the old air scoop. I got to the job and found they had sent the wrong size. As to level and square, ummm it never saw a level. I actually use a laser level to give me a line to follow and then just shoot it by eye. It's not perfect but when your under the gun it's quick...I have to do something to keep up with your level of work..:)
  • Ken_8
    Ken_8 Member Posts: 1,640
  • eleft_4
    The bite you later thing
    The oil pump is easy, 2 screws and hang it on the return, not as easy on the supply. It looks like it all comes out when you have to replace a circulator.
    again great work,
    al
  • Weezbo
    Lchmb
    I have just found out where my guys been hanging out all winter...they named one of thier charaters in an RPG online game Weezbo and he is a 50 th level Necromancer :) i think these guys figure i am a magician Wait till i get the twist on one of thier ears :)they have me write up in the Camalot hearald :) and the other ones on the star wars site and named a Planet or bought a planet and named it after me :)) no wonder everyone wonders how i find time to get the work done :))it must take like a million hours to get to the levels these guys play at :)))
    EBEBRATT-Ed Member Posts: 19,625
    Great job! and nice looking as well. It's nice to see someone take pride in there work.
    ED
