pump sizing
pw
Member Posts: 2
Hello, Would anyone know of a good website where a guy could learn more about sizing pumps for hydronic heating systems. For floor heat or other systems, thanks, Pdeck
pump sizing
I'd recommend getting to a training class. Grundfos' training schedule can be found at the following address:
http://www.grundfos.com/web/homeus.nsf/Webopslag/87A3C20FFD305C4A88256D190077667F
I B R school is another excellent choice for good hydronic training.
The basic information you'll need to select the proper circulator for a closed loop hydronic system is:
Heating load of the area and the Delta T of the system
- This information allows you to determine the flow rate.
Friction loss of the distribution network
- based on flow rate and pipe and fittings
Power available (110v, etc)0
- 167 Indoor-Air Quality
