pump sizing
pw
pw Member Posts: 2
Hello, Would anyone know of a good website where a guy could learn more about sizing pumps for hydronic heating systems. For floor heat or other systems, thanks, Pdeck
  • Ruch Corcoran
    Ruch Corcoran Member Posts: 4
    pump sizing
    I'd recommend getting to a training class. Grundfos' training schedule can be found at the following address:
    http://www.grundfos.com/web/homeus.nsf/Webopslag/87A3C20FFD305C4A88256D190077667F
    I B R school is another excellent choice for good hydronic training.
    The basic information you'll need to select the proper circulator for a closed loop hydronic system is:
    Heating load of the area and the Delta T of the system
    - This information allows you to determine the flow rate.
    Friction loss of the distribution network
    - based on flow rate and pipe and fittings
    Power available (110v, etc)
