steamstorage tank
bob young
Member Posts: 2,177
anyone ever control a steam storage w/ internal coil[ heat exchanger ] with a solenoid valve and aqastat ? how many pounds pressure max. maintenence man scrapping spence valve and designing his own system.comments welcome
Why...
... would you want to get rid of a modulating control valve, and go with an on-off valve like a solenoid? Even if it's sized correctly (most aren't), the solendoid will "hunt" at low loads, banging on and off repeatedly. If it's seriously oversized (most are), it'll "hunt" even at high loads.
What is the steam safety valve setting? I see a lot of ASCO solenoids installed in systems that operate at 125 PSIG or under, but the safety valve that protects the system lifts at 150. I've never seen an ASCO rated for more than 125 steam.0 -
modul. valve
thanks,tony. my thoughts exactly. seems like this guy is trying to blow up this bldg.he is running ten pounds steam for a two storey facility.0 -
modul. valve
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
