Source for Rigid Pipe Insulation
Constantin
Member Posts: 3,796
...where I can buy rigid pipe insulation. Foam is probably OK, considering the temperatures (less than 160°F) though I think I prefer fiberglass in case things get toastier. Where in the Boston, MA area do you recommend a mere homeowner go to buy said insulation to surprise his heating contractor with?
For example, the Dow Corning stuff looks tasty, yet a local source seems to elude me. I'd like to avoid Home Despot and Lowes, if possible. Any ideas?
Constantin, most supply houses sell fiberglass insulation. But Homans Associates, a sheet metal distributor sell a lot of fiber glass insulation.
PATRIOT HEATING & COOLING, INC.
behind the home depot in somerville ma there is a building that has a block of stores look for mysic insulation in that building0 -
where you are
in Cambridge, I think the closest is Metropolitan Pipe and Supply. At least, I think that's what it's called. It's right next to Kendall square. Binney street, I believe.
That's where I got mine. I was pleasantly surprised at how inexpensive it was.
-Michael
Thanks Guys!
You're the best. I'll try to stop by today to get an idea what I need, then it's off to the store for some insulation. Thanks again!0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
