Bell @ Gosset motor
tim_20
Member Posts: 41
Looking for a replacement for a bell and gosset 1/4 h.p. motor part # M95171 115 volt the bell and gosset web site says its obsolete any one know the replacement number and a good dealer in ma.
Thanks Tim
Thanks Tim
no .do not. howsomever...electrical motor rebuilders can..
make you one and often have the exact motor on the shelf...or you could also take the opportunity to change to a more recent version of the bell and gosset...Good luck *~/:)0 -
replace
the circulator. Next week maybe the bearing assem. will fail, and you will be ahead of your game with a brand new pump.0 -
Is that a 2-1/2\" or 3\" circulator?
If so, it might be better to just replace the motor now. This would not require draining and refilling the entire system.
The current B&G part number for the 1/4-hp motor is 111040, and is shown for use on the 2-1/2" and low-delivery 3" models.
If your circulator is very old however, it would make more sense to replace it as the current parts may no longer fit.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
I didn't look at the size of the pipes its a friend of mine who just bought a package store and i know the bearing cartridge was done last spring just trying to help out a friend and save him some money. will call around in the a.m. to my suppliers and see what available. the motor does look like the original but i know over tje years the bearing cartridges have been done. thanks guys0 -
b&g pump
Hi Tim I don't know what area your'e in but in the chicago area , the Sid Harvey co sells rebuilt/exchange B&G motors . check them out , theyr'e great and reasonable too . LOL Jack I'm sure they have mail order , heck if your'e not too far i'll drop it off myself and visit if there's a dunkin in the 'hood . I'm retired and bored , be glad to get away .0 -
You should try the new B&G ball bearing motor. They are cheaper than the old motors and you do not have to oil them. Here is the information I got off www.patriot-supply.com who stocks this motor if you just want to purchase it over the internet.
BELL & GOSSETT 169239
BELL & GOSSETT BALL BEARING MOTOR 1/4HP 115/230 VOLTS 1 PH USE W/ 2 1/2", LD-3 replaces 111040
