Bell @ Gosset motor
tim_20
tim_20 Member Posts: 41
Looking for a replacement for a bell and gosset 1/4 h.p. motor part # M95171 115 volt the bell and gosset web site says its obsolete any one know the replacement number and a good dealer in ma.
Thanks Tim
  • Weezbo
    Weezbo Member Posts: 6,231
    no .do not. howsomever...electrical motor rebuilders can..
    make you one and often have the exact motor on the shelf...or you could also take the opportunity to change to a more recent version of the bell and gosset...Good luck *~/:)
  • jim lockard_2
    jim lockard_2 Member Posts: 4
    replace
    the circulator. Next week maybe the bearing assem. will fail, and you will be ahead of your game with a brand new pump.
    Steamhead Member Posts: 18,211
    Is that a 2-1/2\" or 3\" circulator?
    If so, it might be better to just replace the motor now. This would not require draining and refilling the entire system.
    The current B&G part number for the 1/4-hp motor is 111040, and is shown for use on the 2-1/2" and low-delivery 3" models.
    If your circulator is very old however, it would make more sense to replace it as the current parts may no longer fit.
    Consulting
  • tim_20
    I didn't look at the size of the pipes its a friend of mine who just bought a package store and i know the bearing cartridge was done last spring just trying to help out a friend and save him some money. will call around in the a.m. to my suppliers and see what available. the motor does look like the original but i know over tje years the bearing cartridges have been done. thanks guys
  • nrgeeman
    nrgeeman Member Posts: 1
    b&g pump
    Hi Tim I don't know what area your'e in but in the chicago area , the Sid Harvey co sells rebuilt/exchange B&G motors . check them out , theyr'e great and reasonable too . LOL Jack I'm sure they have mail order , heck if your'e not too far i'll drop it off myself and visit if there's a dunkin in the 'hood . I'm retired and bored , be glad to get away .
  • Pete_16
    Pete_16 Member Posts: 11
    You should try the new B&G ball bearing motor. They are cheaper than the old motors and you do not have to oil them. Here is the information I got off www.patriot-supply.com who stocks this motor if you just want to purchase it over the internet.
    BELL & GOSSETT 169239
    BELL & GOSSETT BALL BEARING MOTOR 1/4HP 115/230 VOLTS 1 PH USE W/ 2 1/2", LD-3 replaces 111040
