Anyone know of a Snow Sensor?
Norbert_2
Member Posts: 6
Wallies:
I have a customer considering a glycol Snow melt for a critical part of an entranceway, he would like to have it "sense" snow on the ground in adddition to OAT to turn it on. Any Ideas?
have not heard of a snow sensor. but there are moisture sensors.0 -
portable snow sensors
I have a couple of guys that always seem to get "sick" or have "personal" problems requiring them to stay home when snow gets near! I guess that ain't what you had in mind, huh?
Couldn't resist. Nope, sorry about the sensors...Guess you could make one.0 -
snow sensor
check out tech-mar they have a sensor that will sense moistor along with tempature which should do the trick.
larry0 -
Snow Sensor
Here is one that is used for satellite dish de-icing systems as well as sidewalk snow melt systems.
http://www.goase.com/ds2.htm
I have not used it, so I can't speak to how well it works.0 -
snow cup
ETI Aerial Precipitation Sensor. www.networketi.com0 -
Also available
from Watts.
LCD-1H
Simple and easy.
Been using and supplying them for 15 years!0 -
411
The Wirsbo 411 is an auotmatic snow and ice melting control with a snow and ice detector. Give me a call if you wnat some help putting this system together. 952-997-5334
Tim D.0
