Anyone know of a Snow Sensor?
Norbert_2
Norbert_2 Member Posts: 6
Wallies:
I have a customer considering a glycol Snow melt for a critical part of an entranceway, he would like to have it "sense" snow on the ground in adddition to OAT to turn it on. Any Ideas?
  • Alan_6
    Alan_6 Member Posts: 87
    have not heard of a snow sensor. but there are moisture sensors.
  • Bob Harper
    Bob Harper Member Posts: 1,109
    portable snow sensors
    I have a couple of guys that always seem to get "sick" or have "personal" problems requiring them to stay home when snow gets near! I guess that ain't what you had in mind, huh?
    Couldn't resist. Nope, sorry about the sensors...Guess you could make one.
  • larry_9
    larry_9 Member Posts: 33
    snow sensor
    check out tech-mar they have a sensor that will sense moistor along with tempature which should do the trick.
    larry
  • ALH_3
    ALH_3 Member Posts: 151
    Tekmar
    Tekmar Controls
    -Andrew
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
  • Matt Clina
    Matt Clina Member Posts: 90
    Snow Sensor
    Here is one that is used for satellite dish de-icing systems as well as sidewalk snow melt systems.
    http://www.goase.com/ds2.htm
    I have not used it, so I can't speak to how well it works.
  • ryan_7
    ryan_7 Member Posts: 50
    snow cup
    ETI Aerial Precipitation Sensor. www.networketi.com
  • Also available
    from Watts.
    LCD-1H
    Simple and easy.
    Been using and supplying them for 15 years!
  • Tim Doran
    Tim Doran Member Posts: 208
    411
    The Wirsbo 411 is an auotmatic snow and ice melting control with a snow and ice detector. Give me a call if you wnat some help putting this system together. 952-997-5334
    Tim D.
