V-belts
Alan_6
Member Posts: 87
Looking for info on v-belts. What is the difference between a A49 or a 4L510 as a example. What the belt tension should be. Or if a units belt cant be identified, how do you know what belt to use.
Vbelts
Get a copy of Grainger's catalogue..there is excellent info in the back of the book regarding belts and how to measure for them. size of pulleys and center-to-center shaft dimensions will give you belt size....good reference book to have around.
Belts
The RSES has good resources available. Check your local chapter or try RSES on the web.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
