An HVAC challenge in central NJ
S. Orbine
Member Posts: 16
I see some pros on this board, people that take pride in their work. I have a real challenge for someone; I have a new installation of a York air handler (with hot water coil for heat). This is a 4-ton variable speed unit for the lower level of a 4600 SF home. This is a failed installation, which the original contractor has abandoned. I have new engineering drawings detailing remediation, which will include complete tearout and re-installation of properly sized ducts, re-sizing of air handler, along with cosmetic and structural repairs to walls, sheetrock, etc...
Is there someone out there who will quote this job? Anyone?
Steve
Steve
steve..
We are located in Essex Co. How close are you? Does not sound too hard.
Robert O'Connor/NJ0 -
Robert, I'm in Bernardsville, NJ (northern Somerset county). How can I contact you?
Steve0 -
Steve
Hit the reply button and scroll up, my e-mail address appears there. Everyones e-mails use to be visible above the posts but hackers started skimming addresses so Dan H hid them there.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
