Vito Fini --PGP
Paul Pollets
Paul Pollets Member Posts: 3,671
The Vitodens replacement commisioned with minor control glitches. (Thanks to James Brown of Viessmann) The system was treated with Rhomar Pro-Tek 922 to assure long serviceability and protection from further O2 corrosion. The VitoCell 53g DHW tank is within 10 feet of the boiler, and heated up to temp in 12 minutes. Notice the false dormer we built on the exterior wall of the mechanical room to vent the unit. We added a few Buderus wall panel rads in an area of the home above the garage that was using electric convectors. The garage uses a large WPR to keep the owner's Porsche cozy.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
