Some more REMS Curvo work
hr
hr Member Posts: 6,106
Ultra/ Viessmann package. Now if I only had a ProPress :) I'd be solder free, needing only a couple press couplings to build these.
Sounds like REMS is bringing in some light weight, less expensive press tools. Supposed to shear all thread, crimp pex, copper press, etc.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Paul Rohrs
    Paul Rohrs Member Posts: 357
    Great work once again.....
    Nice craftsmanship Hotrod!
    I have noticed a wide variety of boilers that you use. They span manufacturer and category. Munchkin, Lochinvar, Weil-McLain.
    Do you have customers requesting specific equipment, or is it availability issues with you vendors? Is your choice of boiler based on $$$$, reliability, or stocked boilers and parts in your region? (Combination of all of the above?)
    Regardless, whatever equipment you use, it is very well done. Perhaps you should have your own REMS Curvo table at the upcoming Wetstock. See ya'there.
    Regards,
    PR
  • hr
    I'm still searching
    for that "perfect 10" boiler, heat sourse, whatever you want to call 'em.
    About the only locally stocked boiler is the Burnham cast iron. A small selection and only standing pilot!
    Actually Burnham or Crown Cabo (sealed combustion) is my favorite "long distance" boiler. Any job more than 45 minutes from my shop gets a good old, solid, dependable, fixable, recognizable, cast iron.
    In the high efficiency range I have a few MZ's, never a problem. 4 Munchkins, a sometimes "needy" boiler, they code out F09 and F10 to often, IMO, and 4 Ultras. So far, with only one season on them, the Ultras have been very dependable.
    The support at HTP would be the only selling feature for my future purchases. I, or the homeowners, have never been left in the cold once you get tech support on the phone :)They need to make the Munchkin more expensive LOOKING, get some better cases. And make the most often tinkered with component (the gas valve) at little easier to service :) Maybe it's the LP quality in my area, but i find the gas valves need re adjusting now and again? Guess time will tell on the stainless de-alloying! If that in fact that can, or is, happening?
    hot rod
  • Ray Landry
    Ray Landry Member Posts: 203
    Thats some nice copper work hot rod. I love the look of bent copper versus fittings. How long did it take you to get that good at knowing just what angle you need? I can still barely bend 1/2 emt lol. I have always wondered that when you bend copper does the outside radius wall thickness of the pipe become thinner? Do you use type M copper for this pipe work or another grade? Once again nice work.
  • Dave Bush
    Dave Bush Member Posts: 155
    In air conditioning,
    We've been using the REMS banders for about 6 years. We always use "soft" "L" (ACR, cleaned and capped on the roll...) with it, and have had ZERO failures in any of the bends. I imagine that it does reduce the wall thickness a tad when bent into a full 90, but it's definitely not noticeable with "L". I've never tried "M", mainly because I don't have access to rolled "M". It would work with "K", also, just probably a bit more effort.
    I will say this about the REMS benders, go slow and steady while making the bends, or you might wind up with a "corrugated" 90...
    It makes a beautiful job, as Hot Rod has shown.
  • Weezbo
    Weezbo Member Posts: 6,231
    Swoopies :)
    my buddy Fred is making a bazillion swoopies this week end :) i have been spinning in a rough in and the blue correan is in on the kitchen counter top as is the hrv ...I will be really interested in what The Freds come up with the last couplea days :) we really gettin into it Hot rod and buddy Wayne says the curvo might be wanting to ride around a coupla days in his new van :)...........we'd like to thank you once again for spinning in some smooth hydronics :)
  • hr
    I use regular L ,stick copper
    It will usually bend type M if you WD-40 the jigs.
    This tool easily bends 1-1/4" K, in fact that is type K in the pic for the cold water feed line to the Vitocell.
    I suppose it does thin the outer radius some. Considering the flow velocity in hydronics and with that long sweep bend, I don't for see any wall thickness wear problems.
    I imagine the ProPress fittings are formed the same way, maybe even regular solder type fittings?
    I don't always hit right on the money with the bends, I have a REMS expander to cheat out a mis calc :)
    This piping took about 30 minutes and replaces 6- ells and 1- 45°
    hot rod
  • Jimmy Gillies
    Jimmy Gillies Member Posts: 250
    REMS Curvo
    Nice work Hot Rod, we bend a lot of copper here in the UK with hand benders and we also have a REMS Curvo. But alas, I found our Curvo in the bowel of our store, when I asked our guys why? 'D' bends, and yes after I tried it myself that's the result I got. But I will try your WD40 trick or get a coulpe of the plastic guides.
    Thanks for reading.
    Regards Jimmy Gillies (Scotland)
  • Weezbo
    Rap on jimmy...
    it now only makes" Uies?"that sounds like maybe something in the trigger ....not allowing it to variable glide out of power....i am interested in how you solve for it and what you think may be the reason for the anomaly...
  • Jimmy Gillies
    WD40
    Another use for WD40 here in the UK, is Pub and Nightclub owners spray all surfaces in their toilets with the stuff, that has the bad effect on any 'substances' being 'snorted' from countertops.
    Oh well, it's pipe bending or mind bending!
    Is the drug problems that we have the price we pay for our rich developed society? Very sad.
    Thanks for reading.
  • joel_19
    joel_19 Member Posts: 933
    HR
    That bender is way cool I need to get one. We have two propress setups gotta love em combine that with the bender and cool things are possable.
    P.S. The people who sold you that water heater also make the perfect heat source . The answer your searching for is right in front of you. Superb fit and finish, unmatched quality, and outstanding efficency , plus the whole package of controlls you need what's not to love?
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    Bending steel
    Anyone try bending steel with that thing? I would like to make some oil lines for my car; they are about 1 inch diam. or 26mm o.d. Is the radius limited to what's shown in the pics or could one get tighter? The Rems cutting oil in the spray cans is an excellent product, by the way.
  • Weezbo
    not yet.... however i priced out some one inch and 3/4 \" ...
    yesterday on my way to work... 17->21 ' long ...sounds Metric to me :) oh..oh,,,i lied 3/4 and 1/2"..oops.shiney chrome looking hospital grade stainless.
  • hr
    I have bent schd 40
    black gasline with it, 1/2". The main thing is that the guides fit the tube diameter closely. It will only bend the diameter of the guides that come with it, the diameter, or radius is not adjustable any closer than the fixture allows.
    I have used that REMS oil, I think it is approved fior domestic water lines oil. Maybe mineral oil or something? Funny smell!
    hot rod
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Mineral oil has no odor, taste or color. May be some fish oil like cod liver--food safe and inexpensive.
  • ScottMP
    ScottMP Member Posts: 5,882
    Their lit. states
    That it is a high alloyed mineral based oil, that can be washedd out with water. " Approved by experts " :) whos that ?
    We use it all the time and like it alot. We use the spray can and its much neater and I have to believe it waste less.
    Scott
  • Plumdog_2
    Measuring bends
    I've watched my electrician buddies bending conduit in multiple directions and having it fit nearly exactly into the boxes that are already mounted. They learn that stuff in apprenticeship school. The makeup distances are marked on some benders for different angles. I gotta get one of those things just for the pure fun of it!
  • EJW
    EJW Member Posts: 321
    OK Hot Rod
    Now tell us about the expander. EJW
  • Tony Conner_2
    Tony Conner_2 Member Posts: 443
    Tube Bending Instructions
    Here's a couple of scans out of "IPT's Pipe Trades Handbook" by Robert A. Lee. The instructions were always long gone for every tube bender I ever came across, but these few pages cover it. Awesome little book, by the way.
    www.iptbooks.com
