pipe water volume?
larry_9
Member Posts: 33
Are you talking gpm of water or volume?
pipe water volume?
I'm looking for a good web site for water volume. What pipes carry, both copper and steel, from 1/2" to 3". Thanks in advance.0 -
gals. per foot
gpm in pipe
formula=Diameter squared in inches multiplied by .0408 multiplied by length in feet = gallons0 -
Gpm for pipe
Ernie:
Pete is right for the volume of pipe. However, if you are talking about gpm then oyu need to take into consideration velocity, other wise you could end up with noise problems. B&G (Bell and Gossett) makes a system sizer for those who design and those who balance systems. It is called a System syzer calculator and it goes up to 3" copper tubing and up to 12" iron pipe I hope this helps.0
- 167 Indoor-Air Quality
